Ga door naar hoofdinhoud
Game Boy Pocket Motherboard Replacement
Adriana Rahrig
Adriana Rahrig en 4 andere bijdragers
Voor het laatst geüpdatet op April 29, 2024
20 - 40 minuten
Gemiddeld
If your Game Boy Pocket does not turn on, you may need to replace the motherboard. The motherboard, the main printed circuit board (PCB), is the central hub where all the parts that make a Game Boy Pocket function meet—such as the sound, power, and visual component. A faulty motherboard can result in a loss of power and functionality in your Game Boy Pocket.
Before using this guide, make sure to test your Game Boy Pocket with fresh batteries. Doing so confirms that the motherboard is the faulty part.
Before beginning, power down your device and remove all batteries.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Game Boy Pocket Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 3 Game Boy Pocket Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 3 Game Boy Pocket Motherboard Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Motherboard Replacement: stap 2, afbeelding 1 van 3 Game Boy Pocket Motherboard Replacement: stap 2, afbeelding 2 van 3 Game Boy Pocket Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket Motherboard Replacement: stap 4, afbeelding 1 van 3 Game Boy Pocket Motherboard Replacement: stap 4, afbeelding 2 van 3 Game Boy Pocket Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Motherboard Replacement: stap 5, afbeelding 1 van 2 Game Boy Pocket Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Motherboard Replacement: stap 6, afbeelding 1 van 2 Game Boy Pocket Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Adriana Rahrig
1.622 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-1, Leahy Fall 2014 Lid van USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 73
Altijd: 5,974
