Ga door naar hoofdinhoud
Game Boy Display Lines/Bars
Mitchell
Mitchell en 5 andere bijdragers
Voor het laatst geüpdatet op August 21, 2024
30 seconden - 1 uur
Gemiddeld
Heeft betere plaatjes nodig
Door de gemeenschap gemaakte handleiding
Fixing the common problem of lines/bars on the original Nintendo Gameboy.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: stap 1, afbeelding 1 van 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: stap 1, afbeelding 2 van 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: stap 1, afbeelding 3 van 3
    • Remove the back housing by removing the 6 Tri-Point or Philip screws.
    • Note: The last 2 screws are in the battery compartment.
  2. Game Boy Display Lines/Bars: stap 2, afbeelding 1 van 2 Game Boy Display Lines/Bars: stap 2, afbeelding 2 van 2
    • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
    • Remove the ribbon cable for the next step.
  3. Game Boy Display Lines/Bars: stap 3, afbeelding 1 van 3 Game Boy Display Lines/Bars: stap 3, afbeelding 2 van 3 Game Boy Display Lines/Bars: stap 3, afbeelding 3 van 3
    • Now there will be screws that mount the board to the front, carefully unscrew these.
    • Now remove the board from the housing.
    • Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Reconnect the the board to back housing with the ribbon cable.
  4. Game Boy Display Lines/Bars: stap 4, afbeelding 1 van 1
    • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • Make sure not to touch the screen itself.
    • Note: There may be a rubber strip covering the ribbon.
    • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Mitchell
184 Reputatie
1 Handleiding geschreven
2 opmerkingen
Hi, this is the second time I attempt this fix, the first time it worked perfectly. The problem is that with this second machine there's a couple of pixel lines that have not tickled back to black even though I have been patiently going over them for quite some time (2 rounds of 10-15 min) is there anything else that I could try or should I just go on over the same area until I see something happen? Thanks in advance
Jose Saura - Antwoord
Use this guide linked below understand where to place the iron under the screen. Step 4 doesn't seem to contain the proper images or details of this step here well enough.
https://www.youtube.com/watch?v=-OEXhxoT...
Bossman207 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 140
Altijd: 5,651
