Ga door naar hoofdinhoud
Game Boy Color Motherboard Replacement
Alex Wu
Alex Wu en 8 andere bijdragers
Voor het laatst geüpdatet op April 27, 2024
30 minuten
Gemiddeld
Uitgelichte handleiding
Uitgelichte studenten-handleiding
The Game Boy Color's motherboard contains all the electronics that make it operate. This guide will show you how to remove the circuit board from the Game Boy Color.
Wat je nodig hebt
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  • Tri-point Y0 Screwdriver
    Tri‑point Y0 Screwdriver
Toon meer…
  1. Game Boy Color Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Game Boy Color Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Motherboard Replacement, Back Housing: stap 3, afbeelding 1 van 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Motherboard Replacement: stap 4, afbeelding 1 van 2 Game Boy Color Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Motherboard Replacement, LCD Ribbon Cable: stap 5, afbeelding 1 van 1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 Game Boy Color Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Gently lift the motherboard from the front housing.
Conclusie
21 andere personen hebben deze handleiding voltooid.
Alex Wu
1.526 Reputatie
2 handleidingen geschreven
Cal Poly, Team 19-47, Regan Winter 2013 Lid van Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Leden
61 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 176
Altijd: 19,176
