Ga door naar hoofdinhoud
Game Boy Advance Back Shell Replacement
Wat je nodig hebt
  1. Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: stap 1, afbeelding 1 van 2 Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: stap 1, afbeelding 2 van 2
    • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge installed, remove it.
    • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
    Vraag FixBot
    Voeg opmerking toe
  2. Game Boy Advance Back Shell Replacement, Remove the battery cover: stap 2, afbeelding 1 van 3 Game Boy Advance Back Shell Replacement, Remove the battery cover: stap 2, afbeelding 2 van 3 Game Boy Advance Back Shell Replacement, Remove the battery cover: stap 2, afbeelding 3 van 3
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
    Vraag FixBot
    Voeg opmerking toe
  3. Game Boy Advance Back Shell Replacement, Remove the batteries: stap 3, afbeelding 1 van 3 Game Boy Advance Back Shell Replacement, Remove the batteries: stap 3, afbeelding 2 van 3 Game Boy Advance Back Shell Replacement, Remove the batteries: stap 3, afbeelding 3 van 3
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
    Vraag FixBot
    Voeg opmerking toe
  4. Game Boy Advance Back Shell Replacement, Remove the back shell screws: stap 4, afbeelding 1 van 2 Game Boy Advance Back Shell Replacement, Remove the back shell screws: stap 4, afbeelding 2 van 2
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
    Vraag FixBot
    Voeg opmerking toe
  5. Game Boy Advance Back Shell Replacement, Remove the back shell: stap 5, afbeelding 1 van 2 Game Boy Advance Back Shell Replacement, Remove the back shell: stap 5, afbeelding 2 van 2
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
5 andere personen hebben deze handleiding voltooid.
Spencer Day
191.052 Reputatie
1.204 handleidingen geschreven
2Gids Commentaar
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
rguich - Antwoord Deel
We've updated the guide, and it now includes the screw measurements.
Spencer Day - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 134
Altijd: 13,407
