Ga door naar hoofdinhoud
GEHEN Portable Clip-On Fan Battery Replacement
Regina Ramirez
Regina Ramirez en 2 andere bijdragers
Voor het laatst geüpdatet op June 19, 2024
15 - 25 minuten
Eenvoudig
If your GEHEN Portable Clip-On Fan no longer turns on or the fan doesn't charge anymore, perhaps it is time to replace the battery. Over time, lithium batteries can begin to lose their efficiency or even stop working altogether. A battery change is needed despite the remaining components being fully functional inside the GEHEN Portable Clip-On Fan. Using a couple of tools, we will go over the steps necessary to replace the battery to extend the shelf life of the GEHEN Portable Clip-On Fan. Along with changing the battery, we will also go over how to dispose of the old batteries properly.
Warning: If one or both of the batteries inside the GEHEN Portable Clip-On Fan are visibly swollen when replacing, take the necessary precautions for dealing with a swollen battery as they can be dangerous and potentially cause a fire. For more information on how to deal with a swollen battery, take a look at this blog post on What to Do With a Swollen iPhone Battery.
Wat je nodig hebt
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. GEHEN Portable Clip-On Fan Battery Replacement, Battery: stap 1, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement, Battery: stap 1, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip the fan over so the back panel is facing you.
  2. GEHEN Portable Clip-On Fan Battery Replacement: stap 2, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 2, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #3 screwdriver to remove the two 20 mm screws from the back panel of the fan.
  3. GEHEN Portable Clip-On Fan Battery Replacement: stap 3, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 3, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to pry the back panel from the fan.
    • If you can't pry between the seam of the panel and the slats, use the empty screw holes to lift the panel up with the pointed end of the spudger.
    • The battery pack is situated in the back panel of the fan, but it is also attached to the body. When removing it, avoid pulling or yanking on the back panel.
  4. GEHEN Portable Clip-On Fan Battery Replacement: stap 4, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 4, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 4, afbeelding 3 van 3
    • Squeeze the tab against the power cable connector, and pull the connector straight up from the socket.
  5. GEHEN Portable Clip-On Fan Battery Replacement: stap 5, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 5, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 5, afbeelding 3 van 3
    • Carefully peel off the tape from both ends of the batteries.
    • Save the battery end protectors to use when reassembling your fan.
  6. GEHEN Portable Clip-On Fan Battery Replacement: stap 6, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 6, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 6, afbeelding 3 van 3
    • Use tin snips to carefully remove the thin piece of metal that connects the ends of the two batteries.
    • Repeat this step on both ends.
    • Since you will need to reuse these metal pieces, be extra careful when cutting them from the batteries. Preserve as much as possible to retain the length of the metal strip.
    • Don't accidentally cut the wires when removing the thing metal!
  7. GEHEN Portable Clip-On Fan Battery Replacement: stap 7, afbeelding 1 van 2 GEHEN Portable Clip-On Fan Battery Replacement: stap 7, afbeelding 2 van 2
    • Once the wires are disconnected, the old batteries can be properly disposed of.
  8. GEHEN Portable Clip-On Fan Battery Replacement: stap 8, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 8, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 8, afbeelding 3 van 3
    • Place electrical tape over the ends of each battery.
    • Take it to a hazardous waste collection point or to a store that cooperates with the disposal of industrial waste and battery recycling such as an electronics store or a home center.
  9. GEHEN Portable Clip-On Fan Battery Replacement: stap 9, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 9, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 9, afbeelding 3 van 3
    • Take the new batteries and reattach the connector.
    • Use the tape cover that was set aside earlier and apply one on each end of the batteries.
    • If necessary, use additional electrical tape to secure the connectors on the ends of the battery pack.
    • Try to not pull or push on the red and black wires to avoid disconnection.
    • Place the battery pack back into the holder on the back panel.
  10. GEHEN Portable Clip-On Fan Battery Replacement: stap 10, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 10, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 10, afbeelding 3 van 3
    • Replace the back panel the two 20 mm screws using the Phillips #3 screwdriver.
  11. GEHEN Portable Clip-On Fan Battery Replacement: stap 11, afbeelding 1 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 11, afbeelding 2 van 3 GEHEN Portable Clip-On Fan Battery Replacement: stap 11, afbeelding 3 van 3
    • Once the back panel has been fastened, ensure that the fan works by pressing the button repeatedly until all the LEDs turn on.
Conclusie
Regina Ramirez
193 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 123
