Ga door naar hoofdinhoud
Fusion5 5.5 Gen II Microphone Replacement
Wat je nodig hebt
    1. Fusion5 5.5 Gen II Microphone Replacement, Back Cover: stap 1, afbeelding 1 van 2 Fusion5 5.5 Gen II Microphone Replacement, Back Cover: stap 1, afbeelding 2 van 2
      • Hold the device with the screen facing away from you and the back of the device facing you.
      • Locate the groove at the bottom corner of the device.
      • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Fusion5 5.5 Gen II Microphone Replacement, Microphone: stap 2, afbeelding 1 van 2 Fusion5 5.5 Gen II Microphone Replacement, Microphone: stap 2, afbeelding 2 van 2
      • The device is rotated upside down here but is not necessary.
      • Remove the six 3mm Phillips #00 screws securing the lower back frame to the device.
      • Slide the lower back frame away, revealing the microphone and the board that it is connected to.
      • When moving the lower back frame, be careful not to rip the wires for the bottom speaker that is attached to the lower back frame.
      Vraag FixBot
      Voeg opmerking toe
    2. Fusion5 5.5 Gen II Microphone Replacement: stap 3, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using the tweezers, grasp the microphone and remove it from its socket on the device.
      • Straighten out the wires to make the next step easier.
      Vraag FixBot
      Voeg opmerking toe
    3. Fusion5 5.5 Gen II Microphone Replacement: stap 4, afbeelding 1 van 3 Fusion5 5.5 Gen II Microphone Replacement: stap 4, afbeelding 2 van 3 Fusion5 5.5 Gen II Microphone Replacement: stap 4, afbeelding 3 van 3
      • Rotate the device or have the bottom of the device facing you for easier access while soldering.
      • Using the tweezers and soldering iron, remove the red and black wires from the circuit board.
      • Make sure that the red wire is on the left connector and the black wire is on the right connector when you solder on the replacement component.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 30
Altijd: 552
