Furnace Humidifier Evaporator Pad Replacement
Inleiding
Ga naar stap 1Furnace humidifiers are built in almost every household and their function is to help add moisture to the air to keep homes warm especially during the winter. If your furnace humidifier is not working optimally and producing enough warmth, this guide is helpful as there are times when you won’t be able to use an old evaporator pad optimally. Eventually, all the dust and particles can cause mold to grow on the evaporator pad. So, to find a solution to this, one would need to buy a new evaporator pad and replace the old one.
Wat je nodig hebt
Turn off the humidifier. (Set the humidistat to 0% humidity)
Enjoy your warm air! Your repair is complete!
