Ga door naar hoofdinhoud
Fujifilm FinePix T500 Motherboard Replacement
Wat je nodig hebt
  1. Fujifilm FinePix T500 Motherboard Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Fujifilm FinePix T500 Motherboard Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Fujifilm FinePix T500 Motherboard Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 Motherboard Replacement: stap 2, afbeelding 1 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 2, afbeelding 2 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Open the battery chamber and remove the battery.
    • Pry the front half of the casing from the camera.
    • Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
  3. Fujifilm FinePix T500 Motherboard Replacement: stap 3, afbeelding 1 van 2 Fujifilm FinePix T500 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 Motherboard Replacement: stap 4, afbeelding 1 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 4, afbeelding 2 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Lift the LCD screen out of the camera.
    • There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
  5. Fujifilm FinePix T500 Motherboard Replacement, Lens: stap 5, afbeelding 1 van 1
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  6. Fujifilm FinePix T500 Motherboard Replacement: stap 6, afbeelding 1 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 6, afbeelding 2 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Pry the center casing off the camera. This is best done by separating the top and side sections individually.
  7. Fujifilm FinePix T500 Motherboard Replacement: stap 7, afbeelding 1 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 7, afbeelding 2 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  8. Fujifilm FinePix T500 Motherboard Replacement: stap 8, afbeelding 1 van 2 Fujifilm FinePix T500 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Pry the metal plate out using the spudger.
  9. Fujifilm FinePix T500 Motherboard Replacement: stap 9, afbeelding 1 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 9, afbeelding 2 van 3 Fujifilm FinePix T500 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
  10. Fujifilm FinePix T500 Motherboard Replacement: stap 10, afbeelding 1 van 2 Fujifilm FinePix T500 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
  11. Fujifilm FinePix T500 Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 1
    • Use tweezers to pull back the plastic covering the top of the camera.
  12. Fujifilm FinePix T500 Motherboard Replacement: stap 12, afbeelding 1 van 2 Fujifilm FinePix T500 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Use tweezers to disconnect both the red and the black wires located next to the flash of the camera.
    • These wires will need to be soldered back in place upon reassembly.
  13. Fujifilm FinePix T500 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Pry off the top circuit board using the spudger.
  14. Fujifilm FinePix T500 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Use tweezers to disconnect the blue and white wires on the underside of the camera.
  15. Fujifilm FinePix T500 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Push the motherboard out of the camera body.
Conclusie
Brian Lasher
313 Reputatie
3 handleidingen geschreven
USF Tampa, Team 19-3, Blackwell Winter 2015 Lid van USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 375
