Ga door naar hoofdinhoud
Flipper Zero Display Replacement
Wat je nodig hebt
      • Go to Main Menu > Settings > Power.
      • Select Power OFF.
      • Alternatively, you can press and hold the Back-button for around 10 seconds.
      • Confirm by pressing the Right-button.
      Vraag FixBot
      Voeg opmerking toe
    1. Flipper Zero Display Replacement, Remove the microSD card: stap 2, afbeelding 1 van 1
      • Eject the microSD card by pressing it with your fingernail.
      Vraag FixBot
      Voeg opmerking toe
    2. Flipper Zero Display Replacement, Remove the screws: stap 3, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Phillips #0 Screwdriver
      $5.49
      • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
      • Be careful, the screws are quite easy to strip.
      Vraag FixBot
      Voeg opmerking toe
    3. Flipper Zero Display Replacement, Open the back cover: stap 4, afbeelding 1 van 3 Flipper Zero Display Replacement, Open the back cover: stap 4, afbeelding 2 van 3 Flipper Zero Display Replacement, Open the back cover: stap 4, afbeelding 3 van 3
      • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
      • Once the latches are released, you can remove the bottom cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Flipper Zero Display Replacement, Seperate the chassis from the top cover: stap 5, afbeelding 1 van 2 Flipper Zero Display Replacement, Seperate the chassis from the top cover: stap 5, afbeelding 2 van 2
      $5.49
      • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
      • Once the screws are removed, separate the chassis from the top cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Flipper Zero Display Replacement, Disconnect the battery: stap 6, afbeelding 1 van 1
      Spudger
      $3.99
      • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
      Vraag FixBot
      Voeg opmerking toe
    1. Flipper Zero Display Replacement, Disconnect the ribbon cable: stap 7, afbeelding 1 van 1
      iFixit Opening Picks (Set of 6)
      $4.95
      • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Flipper Zero Display Replacement, Release the battery chassis: stap 8, afbeelding 1 van 2 Flipper Zero Display Replacement, Release the battery chassis: stap 8, afbeelding 2 van 2
      • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
      • Be sure to apply gentle and consistent pressure to avoid damaging the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Flipper Zero Display Replacement, Unscrew the the button chassis: stap 9, afbeelding 1 van 1
      $5.49
      • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Flipper Zero Display Replacement, Seperate the button chassis: stap 10, afbeelding 1 van 3 Flipper Zero Display Replacement, Seperate the button chassis: stap 10, afbeelding 2 van 3 Flipper Zero Display Replacement, Seperate the button chassis: stap 10, afbeelding 3 van 3
      • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
      Vraag FixBot
      Voeg opmerking toe
    5. Flipper Zero Display Replacement, Disconnect the screen: stap 11, afbeelding 1 van 2 Flipper Zero Display Replacement, Disconnect the screen: stap 11, afbeelding 2 van 2
      $4.95
      • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
      Vraag FixBot
      Voeg opmerking toe
    6. Flipper Zero Display Replacement, Desolder the screen: stap 12, afbeelding 1 van 1
      • To remove the screen you need to desolder two contacts.
      • See this guide on how to solder and desolder connections.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
17 andere personen hebben deze handleiding voltooid.
Sebastian
33.422 Reputatie
72 handleidingen geschreven
14Gids Commentaar
Everything worked fine following this guide. Thank you for the help. In my case was just the glass that was broken, so at the end, i didnt needed to desolder. Just removed the glass with the Plastic pick and worked perfectly. Thank you again for the help.
arthureldo - Antwoord Deel
Where did you find a replacement glass?
Ben Durrant - Antwoord Deel
The company behind FZ is not selling screen replacement (they promise they will do it in the future) but for now... So i don't what to think about this guide
Gusbill - Antwoord Deel
Where can you get an LCD replacement (backlit)?
David Williams - Antwoord Deel
Checked with Flipper Zero Support and they said there's no replacement screens available. Found one on AliExpress and ordered it so I'll post here in about a month once the display has arrived and I have time to try the replacement, then report back and link the part if successful.
Cody Ouellette - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 436
Altijd: 27,265
