Ga door naar hoofdinhoud
Fixing Epson Stylus Photo 1400 Paper Jam
Xin Chen
Xin Chen en 3 andere bijdragers
Voor het laatst geüpdatet op March 25, 2023
1 - 5 minuten
Eenvoudig
This guide shows how to repair a paper jam. This process requires no necessary tools or knowledge of the device.
  1. Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: stap 1, afbeelding 1 van 2 Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: stap 1, afbeelding 2 van 2
    • The paper indicator light blinks red if a paper jam occurs. It might have an unusual clicking noise.
    • Press paper button to eject paper.
    • If previous step does not work, turn off the printer and proceed to step 2. Else, proceed to step 4.
  2. Fixing Epson Stylus Photo 1400 Paper Jam: stap 2, afbeelding 1 van 1
    • Attempt to remove paper by gently and slowly pulling the paper out from the top.
    • Pull the paper as straight as possible.
    • If this does not work, proceed to step 3. Else, proceed to step 4.
  3. Fixing Epson Stylus Photo 1400 Paper Jam: stap 3, afbeelding 1 van 3 Fixing Epson Stylus Photo 1400 Paper Jam: stap 3, afbeelding 2 van 3 Fixing Epson Stylus Photo 1400 Paper Jam: stap 3, afbeelding 3 van 3
    • Open cover of the printer.
    • Gently pull out the paper through the hatch.
    • If ink cartridge is in the way, gently push it off to the side.
    • Close cover.
  4. Fixing Epson Stylus Photo 1400 Paper Jam: stap 4, afbeelding 1 van 1
    • If you had success in step 1, paper indicator light should now return to the normal color green.
    • If you had success in step 2 or 3, turn on printer and press paper button.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Xin Chen
1.105 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-11, Regan Fall 2011 Lid van Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Leden
12 handleidingen geschreven
2 opmerkingen
hi my printer(1400) won't print anything whenever I try to print it stacks and then two lights starts blinking on the computer it's saying fetal error paper jam please help me
nkumbu namukoko - Antwoord
My machine is Epson 1500w ,it make an unusual noise when printing to the middle of the paper and stop lwith the red light blinkinig. Please I need heklp
stephen Banguu-Wobnyine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 7,055
