Ga door naar hoofdinhoud
Fitbit Surge GPS Replacement
Angela Pitts
Angela Pitts en 2 andere bijdragers
Voor het laatst geüpdatet op October 10, 2017
20 minuten
Gemiddeld
Having trouble with your Fitbit Surge's GPS? Read this guide to learn how to replace the GPS, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: stap 1, afbeelding 1 van 2 Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: stap 1, afbeelding 2 van 2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge GPS Replacement: stap 2, afbeelding 1 van 3 Fitbit Surge GPS Replacement: stap 2, afbeelding 2 van 3 Fitbit Surge GPS Replacement: stap 2, afbeelding 3 van 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge GPS Replacement: stap 3, afbeelding 1 van 2 Fitbit Surge GPS Replacement: stap 3, afbeelding 2 van 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge GPS Replacement: stap 4, afbeelding 1 van 2 Fitbit Surge GPS Replacement: stap 4, afbeelding 2 van 2
    • Use a PH000 screw head to undo the newly revealed 4 mm Phillips screws that were hidden beneath the glue.
Conclusie
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
3 andere personen hebben deze handleiding voltooid.
Angela Pitts
1.187 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Leahy Fall 2016 Lid van USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
3 Leden
1Gids Commentaar
Where do you get the parts to replace the GPS or the screen ?
Christine Arends - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 2,993
