Ga door naar hoofdinhoud
Fairphone 4 Battery Replacement
Wat je nodig hebt
  1. Fairphone 4 Battery Replacement, Pry the back cover up: stap 1, afbeelding 1 van 2 Fairphone 4 Battery Replacement, Pry the back cover up: stap 1, afbeelding 2 van 2
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Battery Replacement: stap 2, afbeelding 1 van 3 Fairphone 4 Battery Replacement: stap 2, afbeelding 2 van 3 Fairphone 4 Battery Replacement: stap 2, afbeelding 3 van 3
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Battery Replacement: stap 3, afbeelding 1 van 3 Fairphone 4 Battery Replacement: stap 3, afbeelding 2 van 3 Fairphone 4 Battery Replacement: stap 3, afbeelding 3 van 3
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Battery Replacement: stap 4, afbeelding 1 van 3 Fairphone 4 Battery Replacement: stap 4, afbeelding 2 van 3 Fairphone 4 Battery Replacement: stap 4, afbeelding 3 van 3
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Battery Replacement, Lever up the Battery: stap 5, afbeelding 1 van 3 Fairphone 4 Battery Replacement, Lever up the Battery: stap 5, afbeelding 2 van 3 Fairphone 4 Battery Replacement, Lever up the Battery: stap 5, afbeelding 3 van 3
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
Conclusie
For optimal performance, calibrate your newly installed battery after completing this guide.
9 andere personen hebben deze handleiding voltooid.
Manuel Haeussermann
19.556 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.637 handleidingen geschreven
1Gids Commentaar
I am not sure steps 2,3,4 are really necessary in this guide.
Bartłomiej Tokarzewski - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 288
Altijd: 9,246
