Ga door naar hoofdinhoud
Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement
Larry Huang
Larry Huang en 11 andere bijdragers
Voor het laatst geüpdatet op October 9, 2024
15 - 30 minuten
Gemiddeld
This guide demonstrates how to replace the paper eject frame assembly in your Epson Stylus Photo 1400 printer. If you're experiencing frequent paper jams, a faulty eject frame may be the cause. This repair requires basic tools and minimal technical experience, making it suitable for most users. Follow these steps to resolve paper jam issues and restore smooth operation.
Wat je nodig hebt
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Housing: stap 1, afbeelding 1 van 1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 2, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 2, afbeelding 2 van 2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 3, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 4, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 5, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 5, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 5, afbeelding 3 van 3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 6, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 6, afbeelding 2 van 2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 7, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 7, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 7, afbeelding 3 van 3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 8, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 8, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 8, afbeelding 3 van 3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 9, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 9, afbeelding 2 van 2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 10, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 11, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 11, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 12, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 12, afbeelding 2 van 2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
  13. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: stap 13, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: stap 13, afbeelding 2 van 2
    • Start by emptying the ink tube.
    • Hold the left side of the ink tube in your hand.
    • Pull the sides of the tube apart and empty the waste.
  14. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 14, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 14, afbeelding 2 van 2
    • Remove the acetate tape that secures the connector cable.
  15. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 15, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 15, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 15, afbeelding 3 van 3
    • There are six screws that secure the printer mechanism.
    • Remove the first three 10 mm screws that hold the printer mechanism in place using a Phillips #2 screwdriver.
  16. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 16, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 16, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 16, afbeelding 3 van 3
    • Remove the other three 10 mm screws that secure the printer mechanism using a Phillips #2 screwdriver.
  17. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 17, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 17, afbeelding 2 van 2
    • The printer mechanism is located on the lower housing.
    • Remove the mechanism by holding the handles and lifting upwards.
  18. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 18, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 18, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 18, afbeelding 3 van 3
    • Remove the CD-R unit housing. Release the two attaching points to the tray base and then pull out the unit diagonally one side at a time.
  19. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 19, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 19, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 19, afbeelding 3 van 3
    • Detach the left frame support plate. Start by removing the two 6 mm screws that secure it and then pull it out by hand.
  20. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 20, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 20, afbeelding 2 van 2
    • Remove the four 6 mm screws using the Phillips #2 screwdriver.
    • Remove the two 8 mm screw using a Phillips #2 screwdriver.
    • The screws are located on the lower sections of the printer.
  21. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 21, afbeelding 1 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 21, afbeelding 2 van 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 21, afbeelding 3 van 3
    • Two guide pins secure the paper eject assembly in place.
    • Pull out the two guide pins on the CD/DVD tray base.
  22. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 22, afbeelding 1 van 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: stap 22, afbeelding 2 van 2
    • Remove the paper eject frame assembly by pulling it towards you.
Conclusie
41 andere personen hebben deze handleiding voltooid.
Larry Huang
1.004 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-11, Regan Fall 2011 Lid van Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 26
Altijd: 21,531
