Ga door naar hoofdinhoud
Epson Stylus Photo 1400 Ink cartridge replacement
Larry Huang
Larry Huang en 3 andere bijdragers
Voor het laatst geüpdatet op March 27, 2023
5 - 10 minuten
Eenvoudig
This guide shows how to replace an Ink Cartridge. This process requires no necessary tools or knowledge of the device.
Wat je nodig hebt
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: stap 1, afbeelding 1 van 2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: stap 1, afbeelding 2 van 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: stap 2, afbeelding 1 van 2 Epson Stylus Photo 1400 Ink cartridge replacement: stap 2, afbeelding 2 van 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: stap 3, afbeelding 1 van 2 Epson Stylus Photo 1400 Ink cartridge replacement: stap 3, afbeelding 2 van 2
    • Close cartridge cover.
    • Close cover of the printer.
Conclusie
Larry Huang
1.004 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-11, Regan Fall 2011 Lid van Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Leden
12 handleidingen geschreven
6 opmerkingen
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Antwoord
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Antwoord
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Antwoord
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Antwoord
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 24
Altijd: 10,303
