Ga door naar hoofdinhoud
Epson Home Cinema 2150 Speaker Replacement
Luis Garcia
Luis Garcia en 4 andere bijdragers
Voor het laatst geüpdatet op December 28, 2022
50 minuten - 1 uur
Gemiddeld
If audio from the 3.5 mm auxiliary connector is clear while audio from the internal speaker in the Epson Home Cinema 2150 is distorted, the internal speaker may need to be replaced.
Looking at the inside of the projector, the speaker is located on the bottom right of the projector, behind the exhaust fan.
Wat je nodig hebt
Gereedschap
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: stap 1, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: stap 1, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: stap 1, afbeelding 3 van 3
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Speaker Replacement: stap 2, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 2, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Speaker Replacement: stap 3, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 3, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
  4. Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: stap 4, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: stap 4, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: stap 4, afbeelding 3 van 3
    • Remove the air filter cover. Grip the piece with two fingers above and below at the center.
    • Grab the air filter from the protruding tab and pull the filter out.
  5. Epson Home Cinema 2150 Speaker Replacement: stap 5, afbeelding 1 van 2 Epson Home Cinema 2150 Speaker Replacement: stap 5, afbeelding 2 van 2
    • From the back of the projector remove three 6 mm Phillips #1 screws.
  6. Epson Home Cinema 2150 Speaker Replacement: stap 6, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 6, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 6, afbeelding 3 van 3
    • From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
    • Remove two 6 mm Phillips #1 screws.
    • Pull off remaining plastic molding.
  7. Epson Home Cinema 2150 Speaker Replacement: stap 7, afbeelding 1 van 2 Epson Home Cinema 2150 Speaker Replacement: stap 7, afbeelding 2 van 2
    • From the lamp access slot, remove four 9.5 mm Philips #1 screws
  8. Epson Home Cinema 2150 Speaker Replacement: stap 8, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 8, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 8, afbeelding 3 van 3
    • From the filter slot, unscrew two 9.5 mm #1 screws.
  9. Epson Home Cinema 2150 Speaker Replacement: stap 9, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 9, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 9, afbeelding 3 van 3
    • Partially lift the top portion of the device housing.
    • Lifting too far or too hard may damage any cables between the housing and the motherboard.
  10. Epson Home Cinema 2150 Speaker Replacement: stap 10, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 10, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 10, afbeelding 3 van 3
    • Disconnect the ribbon cable from the motherboard.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of two fingers.
  11. Epson Home Cinema 2150 Speaker Replacement: stap 11, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 11, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 11, afbeelding 3 van 3
    • Remove three 5 mm Phillips #1 screws.
  12. Epson Home Cinema 2150 Speaker Replacement: stap 12, afbeelding 1 van 2 Epson Home Cinema 2150 Speaker Replacement: stap 12, afbeelding 2 van 2
    • Press on the metal connector and firmly pull on the remaining ribbon cable.
  13. Epson Home Cinema 2150 Speaker Replacement: stap 13, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 13, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 13, afbeelding 3 van 3
    • Pull the clips on the case with two fingers on opposite ends and remove the case.
  14. Epson Home Cinema 2150 Speaker Replacement, Speaker: stap 14, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement, Speaker: stap 14, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement, Speaker: stap 14, afbeelding 3 van 3
    • Pull up on the rear panel retaining clip.
    • Pull the rear panel away from the device to remove.
  15. Epson Home Cinema 2150 Speaker Replacement: stap 15, afbeelding 1 van 2 Epson Home Cinema 2150 Speaker Replacement: stap 15, afbeelding 2 van 2
    • Disconnect the speaker wire from the motherboard.
    • Pull up at the end of the wire when removing the connector.
  16. Epson Home Cinema 2150 Speaker Replacement: stap 16, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 16, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 16, afbeelding 3 van 3
    • Unwind the speaker wire through the metal chassis.
  17. Epson Home Cinema 2150 Speaker Replacement: stap 17, afbeelding 1 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 17, afbeelding 2 van 3 Epson Home Cinema 2150 Speaker Replacement: stap 17, afbeelding 3 van 3
    • Remove two 6mm Phillips #1 screws.
    • The speaker will fall out once screws are removed.
Conclusie
Luis Garcia
577 Reputatie
4 handleidingen geschreven
CSU Los Angeles, Team 6-2, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-2, Adachi Fall 2022
CSULA-ADACHI-F22S6G2
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 132
