Ga door naar hoofdinhoud
DualSense Motherboard Replacement
Wat je nodig hebt
  1. DualSense Motherboard Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 1 van 2 DualSense Motherboard Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 2 van 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Motherboard Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 1 van 3 DualSense Motherboard Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 2 van 3 DualSense Motherboard Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 3 van 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Motherboard Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 1 van 2 DualSense Motherboard Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 2 van 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Motherboard Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 1 van 3 DualSense Motherboard Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 2 van 3 DualSense Motherboard Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Motherboard Replacement, Remove the middle trim: stap 5, afbeelding 1 van 3 DualSense Motherboard Replacement, Remove the middle trim: stap 5, afbeelding 2 van 3 DualSense Motherboard Replacement, Remove the middle trim: stap 5, afbeelding 3 van 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. DualSense Motherboard Replacement, Remove the L1 button: stap 6, afbeelding 1 van 3 DualSense Motherboard Replacement, Remove the L1 button: stap 6, afbeelding 2 van 3 DualSense Motherboard Replacement, Remove the L1 button: stap 6, afbeelding 3 van 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. DualSense Motherboard Replacement, Remove the R1 button: stap 7, afbeelding 1 van 3 DualSense Motherboard Replacement, Remove the R1 button: stap 7, afbeelding 2 van 3 DualSense Motherboard Replacement, Remove the R1 button: stap 7, afbeelding 3 van 3
    • Repeat the previous step to remove the R1 button.
  8. DualSense Motherboard Replacement, Remove the rear case screws: stap 8, afbeelding 1 van 2 DualSense Motherboard Replacement, Remove the rear case screws: stap 8, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. DualSense Motherboard Replacement: stap 9, afbeelding 1 van 2 DualSense Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. DualSense Motherboard Replacement, Separate the rear case: stap 10, afbeelding 1 van 3 DualSense Motherboard Replacement, Separate the rear case: stap 10, afbeelding 2 van 3 DualSense Motherboard Replacement, Separate the rear case: stap 10, afbeelding 3 van 3
    • Be gently when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. DualSense Motherboard Replacement: stap 11, afbeelding 1 van 3 DualSense Motherboard Replacement: stap 11, afbeelding 2 van 3 DualSense Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. DualSense Motherboard Replacement: stap 12, afbeelding 1 van 3 DualSense Motherboard Replacement: stap 12, afbeelding 2 van 3 DualSense Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Repeat the previous step on the right edge to release its clips.
  13. DualSense Motherboard Replacement: stap 13, afbeelding 1 van 2 DualSense Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. DualSense Motherboard Replacement, Remove the rear case: stap 14, afbeelding 1 van 1
    • Remove the rear case.
  15. DualSense Motherboard Replacement, Disconnect the battery: stap 15, afbeelding 1 van 2 DualSense Motherboard Replacement, Disconnect the battery: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  16. DualSense Motherboard Replacement, Remove the battery: stap 16, afbeelding 1 van 2 DualSense Motherboard Replacement, Remove the battery: stap 16, afbeelding 2 van 2
    • Lift the battery straight out of the battery bracket.
  17. DualSense Motherboard Replacement, Remove the lower microphone: stap 17, afbeelding 1 van 2 DualSense Motherboard Replacement, Remove the lower microphone: stap 17, afbeelding 2 van 2
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  18. DualSense Motherboard Replacement, Remove the battery bracket: stap 18, afbeelding 1 van 2 DualSense Motherboard Replacement, Remove the battery bracket: stap 18, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. DualSense Motherboard Replacement: stap 19, afbeelding 1 van 2 DualSense Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Lift the battery bracket out of the motherboard.
  20. DualSense Motherboard Replacement, Disconnect the right trigger assembly: stap 20, afbeelding 1 van 2 DualSense Motherboard Replacement, Disconnect the right trigger assembly: stap 20, afbeelding 2 van 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  21. DualSense Motherboard Replacement: stap 21, afbeelding 1 van 2 DualSense Motherboard Replacement: stap 21, afbeelding 2 van 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  22. DualSense Motherboard Replacement, Disconnect the left trigger assembly: stap 22, afbeelding 1 van 2 DualSense Motherboard Replacement, Disconnect the left trigger assembly: stap 22, afbeelding 2 van 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. DualSense Motherboard Replacement: stap 23, afbeelding 1 van 2 DualSense Motherboard Replacement: stap 23, afbeelding 2 van 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. DualSense Motherboard Replacement, Disconnect the upper microphone: stap 24, afbeelding 1 van 2 DualSense Motherboard Replacement, Disconnect the upper microphone: stap 24, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  25. DualSense Motherboard Replacement, Disconnect the touchpad: stap 25, afbeelding 1 van 2 DualSense Motherboard Replacement, Disconnect the touchpad: stap 25, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. DualSense Motherboard Replacement, Lift out the motherboard: stap 26, afbeelding 1 van 3 DualSense Motherboard Replacement, Lift out the motherboard: stap 26, afbeelding 2 van 3 DualSense Motherboard Replacement, Lift out the motherboard: stap 26, afbeelding 3 van 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  27. DualSense Motherboard Replacement, Desolder the vibration motors: stap 27, afbeelding 1 van 3 DualSense Motherboard Replacement, Desolder the vibration motors: stap 27, afbeelding 2 van 3 DualSense Motherboard Replacement, Desolder the vibration motors: stap 27, afbeelding 3 van 3
    • The next few steps require desoldering and soldering connections. To learn how to solder, check out our soldering guide—if you've already soldered, you can still find some helpful tips and tricks in this guide!
    • Flip over the controller and motherboard.
    • Use a soldering iron to desolder the vibration motor wires from the motherboard:
    • Two red wires
    • Two black wires
    • During reassembly, remember to solder the wires back into the same position. The red wires belong closest to the edge and next to the Rs on the motherboard.
  28. DualSense Motherboard Replacement: stap 28, afbeelding 1 van 1
    • Separate the controller from the motherboard.
  29. DualSense Motherboard Replacement, Remove the joystick covers: stap 29, afbeelding 1 van 3 DualSense Motherboard Replacement, Remove the joystick covers: stap 29, afbeelding 2 van 3 DualSense Motherboard Replacement, Remove the joystick covers: stap 29, afbeelding 3 van 3
    • Pull the joystick covers straight off the joystick assemblies.
    • Only the motherboard remains.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Sam Omiotek
83.744 Reputatie
290 handleidingen geschreven
3 opmerkingen
Where can you buy a new motherboard in the UK?
adam.williams.95 - Antwoord
Cool tutorial, all we need now is to know which chip slows the input 5v current to only push 1.5A then we would be able to get a service which can enable fast charge. Karl brook.
karl brook - Antwoord
what size capacitors are used near the toggle controller, there is one near the right joystick and another by the left joystick at the bottom right.
any help would be apreciated.
bill beddow - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 56
Afgelopen 7 dagen: 355
Afgelopen 30 dagen: 1,195
Altijd: 39,180
