Ga door naar hoofdinhoud
DualSense Controller v2 Adaptive Trigger Replacement
Wat je nodig hebt
    1. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 2 van 2
      • Disconnect and power down the controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    2. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 3 van 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    3. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 2 van 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    4. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 3 van 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    5. DualSense Controller v2 Adaptive Trigger Replacement, Remove the middle trim: stap 5, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the middle trim: stap 5, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the middle trim: stap 5, afbeelding 3 van 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
      Vraag FixBot
      Voeg opmerking toe
    1. DualSense Controller v2 Adaptive Trigger Replacement, Remove the L1 button: stap 6, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the L1 button: stap 6, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the L1 button: stap 6, afbeelding 3 van 3
      • Insert the flat end of a spudger into the gap above the L1 button.
      • Cover the button with your thumb to prevent it from ejecting across the room.
      • Pry the spudger upward to remove the L1 button.
      Vraag FixBot
      Voeg opmerking toe
    2. DualSense Controller v2 Adaptive Trigger Replacement, Remove the R1 button: stap 7, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the R1 button: stap 7, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the R1 button: stap 7, afbeelding 3 van 3
      • Insert the flat end of a spudger into the gap above the R1 button.
      • Pry the spudger upward to remove the R1 button.
      Vraag FixBot
      Voeg opmerking toe
    1. DualSense Controller v2 Adaptive Trigger Replacement, Remove the case screws: stap 8, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
      Vraag FixBot
      Voeg opmerking toe
    2. DualSense Controller v2 Adaptive Trigger Replacement: stap 9, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
      Vraag FixBot
      Voeg opmerking toe
    3. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the rear case: stap 10, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the rear case: stap 10, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the rear case: stap 10, afbeelding 3 van 3
      • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
      Vraag FixBot
      Voeg opmerking toe
    4. DualSense Controller v2 Adaptive Trigger Replacement, Remove the rear case: stap 11, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Remove the rear case: stap 11, afbeelding 2 van 2
      • Use your hands to carefully pull the rear case off of the controller.
      • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
      Vraag FixBot
      Voeg opmerking toe
    1. DualSense Controller v2 Adaptive Trigger Replacement, Reposition the battery: stap 12, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Reposition the battery: stap 12, afbeelding 2 van 2
      • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
      • Don't strain the battery cables.
      Vraag FixBot
      Voeg opmerking toe
    2. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the battery: stap 13, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the battery: stap 13, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Don't pull on the wires to disconnect the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. DualSense Controller v2 Adaptive Trigger Replacement, Remove the battery: stap 14, afbeelding 1 van 1
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. DualSense Controller v2 Adaptive Trigger Replacement, Remove the lower microphone: stap 15, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Remove the lower microphone: stap 15, afbeelding 2 van 2
      • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
      • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
      Vraag FixBot
      Voeg opmerking toe
    2. DualSense Controller v2 Adaptive Trigger Replacement: stap 16, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement: stap 16, afbeelding 2 van 2
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. DualSense Controller v2 Adaptive Trigger Replacement, Remove the battery bracket: stap 17, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
      Vraag FixBot
      Voeg opmerking toe
    4. DualSense Controller v2 Adaptive Trigger Replacement: stap 18, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement: stap 18, afbeelding 2 van 2
      • Lift the battery bracket off of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the right trigger assembly: stap 19, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the right trigger assembly: stap 19, afbeelding 2 van 2
      • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
      • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
      • Don't completely remove the ribbon cable yet.
      Vraag FixBot
      Voeg opmerking toe
    6. DualSense Controller v2 Adaptive Trigger Replacement: stap 20, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement: stap 20, afbeelding 2 van 2
      • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
      • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
      Vraag FixBot
      Voeg opmerking toe
    7. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the left trigger assembly: stap 21, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the left trigger assembly: stap 21, afbeelding 2 van 2
      • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    8. DualSense Controller v2 Adaptive Trigger Replacement: stap 22, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement: stap 22, afbeelding 2 van 2
      • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
      Vraag FixBot
      Voeg opmerking toe
    9. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the upper microphone: stap 23, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the upper microphone: stap 23, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
      • If you're not replacing this microphone, don't remove it from the frame.
      Vraag FixBot
      Voeg opmerking toe
    10. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the touchpad: stap 24, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the touchpad: stap 24, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    11. DualSense Controller v2 Adaptive Trigger Replacement, Lift out the motherboard: stap 25, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Lift out the motherboard: stap 25, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Lift out the motherboard: stap 25, afbeelding 3 van 3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
      Vraag FixBot
      Voeg opmerking toe
    1. DualSense Controller v2 Adaptive Trigger Replacement, Remove the light guide: stap 26, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the light guide: stap 26, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the light guide: stap 26, afbeelding 3 van 3
      • Use the pointed end of your spudger to lift the center of the light guide out of the controller.
      • Remove the light guide.
      Vraag FixBot
      Voeg opmerking toe
    1. DualSense Controller v2 Adaptive Trigger Replacement, Remove the midframe: stap 27, afbeelding 1 van 1
      • Use your Phillips driver to remove the two 6.5 mm screws securing the midframe to the front case.
      Vraag FixBot
      Voeg opmerking toe
    2. DualSense Controller v2 Adaptive Trigger Replacement: stap 28, afbeelding 1 van 3 DualSense Controller v2 Adaptive Trigger Replacement: stap 28, afbeelding 2 van 3 DualSense Controller v2 Adaptive Trigger Replacement: stap 28, afbeelding 3 van 3
      • Carefully lift the midframe and motherboard up and out of the front case.
      • Be careful not to strain the vibrator motor wires.
      • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
      Vraag FixBot
      Voeg opmerking toe
    1. DualSense Controller v2 Adaptive Trigger Replacement, Remove the adaptive triggers: stap 29, afbeelding 1 van 1
      • Use your Phillips screwdriver to remove the four 6.5 mm screws securing the adaptive triggers to the midframe.
      • The adaptive triggers are loose and will fall out of the midframe.
      • During reassembly, verify the conductive membrane is properly aligned by checking the screw holes and alignment posts.
      • Proper alignment of the conductive membrane is essential for button functionality.
      Vraag FixBot
      Voeg opmerking toe
    2. DualSense Controller v2 Adaptive Trigger Replacement: stap 30, afbeelding 1 van 2 DualSense Controller v2 Adaptive Trigger Replacement: stap 30, afbeelding 2 van 2
      • Lift the midframe off of the adaptive triggers.
      • Be careful not to pull the vibration motor wires out of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Sam Omiotek
99.897 Reputatie
289 handleidingen geschreven
4Gids Commentaar
Anyone knows where to buy the Adaptive Triggers for this controller model, CFI-ZCT1W? Thanks in advance.
Obel Ortiz - Antwoord Deel
This is wrong. Not the instructions for V2 as V2 removed the screws that hold the adaptive triggers so now it's impossible to remove them.
Glen Senecal - Antwoord Deel
Does anyone know how to replace the l2 and r2 bumpers? I need to remove for a controller mod
MalicePalace - Antwoord Deel
For a BDM-020 controller, extremerate has a video about installing a clicky kit that requires you to take off the trigger caps. They also have mods for other controller versions, so I assume they have videos for those controller variations too.
https://youtu.be/JSpm7piCqgQ?si=SyotXDne...
Lone - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 204
Afgelopen 30 dagen: 946
Altijd: 28,125
