Ga door naar hoofdinhoud
Droid Ultra XT1080 Power Button Replacement
knoyes
knoyes en 2 andere bijdragers
Voor het laatst geüpdatet op May 16, 2024
35 minuten
Gemiddeld
This guide will show you how to properly replace the power button on your Motorola Droid Ultra XT 1080
Wat je nodig hebt
Gereedschap
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
Toon meer…
  1. Droid Ultra XT1080 Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 Droid Ultra XT1080 Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 Droid Ultra XT1080 Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
    • Gently remove the SIM card tray from the device using a spudger.
  2. Droid Ultra XT1080 Power Button Replacement: stap 2, afbeelding 1 van 1
    • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • Work your way around the device until all the clips are released.
    • Be gentle while doing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Power Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Power Button Replacement: stap 4, afbeelding 1 van 2 Droid Ultra XT1080 Power Button Replacement: stap 4, afbeelding 2 van 2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Power Button Replacement: stap 5, afbeelding 1 van 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Power Button Replacement: stap 6, afbeelding 1 van 1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Power Button Replacement: stap 7, afbeelding 1 van 2 Droid Ultra XT1080 Power Button Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    $3.99
    • Once motherboard is removed you have gained access to the power button.
    • Gently, using a pair of angled tweezers pull on the power button to remove it.
Conclusie
knoyes
785 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 24
Altijd: 348
