Ga door naar hoofdinhoud
Droid Ultra XT1080 Battery Replacement
knoyes
knoyes en een andere bijdrager
Voor het laatst geüpdatet op March 4, 2022
30 minuten
Gemiddeld
This guide is to replace a damaged battery on the Motorola Droid XT 1080. It is important because your phone will not charge or turn on if the battery needs to be replaced.
Wat je nodig hebt
Gereedschap
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
Toon meer…
  1. Droid Ultra XT1080 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
  2. Droid Ultra XT1080 Battery Replacement: stap 2, afbeelding 1 van 1
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Battery Replacement: stap 4, afbeelding 1 van 2 Droid Ultra XT1080 Battery Replacement: stap 4, afbeelding 2 van 2
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
  5. Droid Ultra XT1080 Battery Replacement: stap 5, afbeelding 1 van 1
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
  6. Droid Ultra XT1080 Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the four T5 Torx screws securing the motherboard.
  7. Droid Ultra XT1080 Battery Replacement: stap 7, afbeelding 1 van 2 Droid Ultra XT1080 Battery Replacement: stap 7, afbeelding 2 van 2
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
  8. Droid Ultra XT1080 Battery Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
Conclusie
3 andere personen hebben deze handleiding voltooid.
knoyes
785 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 3,098
