Disassembling Motorola Droid Camera
Inleiding
Ga naar stap 1You've already gotten To the Camera Assembly, so why not go just a bit further? Lint can easily get in and wreak havoc with the micro-ball-bearings found within the camera assembly, and cleaning the assembly iis quite straightforward. Beware: Really Teeny Parts ahead!!
Wat je nodig hebt
Gereedschap
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Disconnect the camera connector from its socket by prying it straight up with a spudger.
Remove the camera assembly.
Use a flat jewelers screwdriver to gently pry up the housing surrounding the Camera lens. Pry up one side first, then the other.
Note the orientation of the Dimple on the side of the cover, as it will need to go on the same way during Reassembly.
3 andere personen hebben deze handleiding voltooid.
