Disassembling Canon EOS Rebel XS Top Panel
Inleiding
Ga naar stap 1Use this guide to remove the top panel of the camera.
Wat je nodig hebt
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Remove three medium length screws from the bottom of the camera
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
Use tweezers to lift the panel.
Remove the following ribbons with the tweezers by gently pulling on them.
Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
Één andere persoon heeft deze handleiding voltooid.
