Ga door naar hoofdinhoud
Denim Jeans Inner Thigh Replacement
chennaultsara
chennaultsara en 4 andere bijdragers
Voor het laatst geüpdatet op June 25, 2019
45 minuten
Eenvoudig
  1. Denim Jeans Inner Thigh Replacement, Inner Thigh: stap 1, afbeelding 1 van 1
    • Use a simple back and forth pattern with the needle and thread to close the holes.
    • This step is to ensure the shape of your patch. It will not be the outright fix to the problem.
  2. Denim Jeans Inner Thigh Replacement: stap 2, afbeelding 1 van 3 Denim Jeans Inner Thigh Replacement: stap 2, afbeelding 2 van 3 Denim Jeans Inner Thigh Replacement: stap 2, afbeelding 3 van 3
    • Use an embroidery hoop as a stencil to trace out the damaged area.
    • Use fabric scissors to cut along the back panel of the jeans. Follow the line.
    • Cut only the back panel or you will have an unnecessary hole in the front of your pants.
  3. Denim Jeans Inner Thigh Replacement: stap 3, afbeelding 1 van 2 Denim Jeans Inner Thigh Replacement: stap 3, afbeelding 2 van 2
    • Place the cutouts in the denim swatch.
    • Trace a larger shape of the cutout.
    • Use fabric scissors to cut out the patches.
  4. Denim Jeans Inner Thigh Replacement: stap 4, afbeelding 1 van 3 Denim Jeans Inner Thigh Replacement: stap 4, afbeelding 2 van 3 Denim Jeans Inner Thigh Replacement: stap 4, afbeelding 3 van 3
    • Center the old denim onto the new patch.
    • Trace vertical and horizontal lines on denim by using a straight edge and some chalk.
    • Pin the old denim in place.
  5. Denim Jeans Inner Thigh Replacement: stap 5, afbeelding 1 van 1
    • Using an embroidery needle and an embroidery floss add stitches into the patch.
    • Use a Straight Stitch (just up and down sewing) following the vertical and then horizontal lines.
    • The embroidery floss comes as a twisted rope. You have to pull the threads from the rope before you can use them.
  6. Denim Jeans Inner Thigh Replacement: stap 6, afbeelding 1 van 1
    • Pin the patch with as little of the new patch showing as possible.
    • Use a Whip Stitch to attach the patch. This is an over/under sewing pattern.
    • Repeat a second time.
    • Turn inside out and trim down the patch. Use a straight stitch to tighten up any loose spots.
  7. Denim Jeans Inner Thigh Replacement, Finished: stap 7, afbeelding 1 van 1
    • The style is meant to look rustic and DIY. By no means is it a professional finish. Still functional and if done right can be quite cute!
Conclusie
This is a rustic or unfinished but functional looking patch for denim jeans.
3 andere personen hebben deze handleiding voltooid.
chennaultsara
197 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 101
Altijd: 5,828
