Ga door naar hoofdinhoud
Dell XPS M1530 Wireless Card Replacement
Jase Sasaki
Jase Sasaki en 6 andere bijdragers
Voor het laatst geüpdatet op January 17, 2018
10 - 15 minuten
Gemiddeld
This guide helps you to upgrade or replace your wireless card to a new Wi-Fi standard if you have determined that the reason your wireless internet is not working is because of a hardware issue with the card.
Wat je nodig hebt
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Dell XPS M1530 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Wireless Card Replacement: stap 3, afbeelding 1 van 2 Dell XPS M1530 Wireless Card Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 1
    • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
    • Two 4.7mm Philips #1 screws
  5. Dell XPS M1530 Wireless Card Replacement: stap 5, afbeelding 1 van 2 Dell XPS M1530 Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Lift the panel up from the indented area.
    • This indent should provide enough grip to remove the panel with ease.
  6. Dell XPS M1530 Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
    • One 3.9mm Phillips #1 screw
  7. Dell XPS M1530 Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • Lift the card out at an angle and carefully remove it.
  8. Dell XPS M1530 Wireless Card Replacement: stap 8, afbeelding 1 van 2 Dell XPS M1530 Wireless Card Replacement: stap 8, afbeelding 2 van 2
    • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
    • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
    • Note the order of colors for the antenna cables indicated on the card.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jase Sasaki
721 Reputatie
5 handleidingen geschreven
Cal Poly, Team 18-4, Maness Winter 2015 Lid van Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 27
Altijd: 1,801
