Ga door naar hoofdinhoud
Dell XPS 720 H2C Memory Modules Replacement
Alexis Cervantes
Alexis Cervantes en 4 andere bijdragers
Voor het laatst geüpdatet op January 28, 2014
10 minuten
Eenvoudig
Actiemomenten
Heeft betere plaatjes nodig
Memory modules allow computers to store electronic memory for users to access at a later time. This guide will show you how to install new memory modules on the Dell XPS 720 H2C, as well as how to reseat the current memory modules on the computer. The procedure is simple and requires minimal disassembly.
  1. Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 1 van 2 Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 2 van 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: stap 2, afbeelding 1 van 3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: stap 2, afbeelding 2 van 3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: stap 2, afbeelding 3 van 3
    • The memory modules are located directly above the XPS processor and are attached to the motherboard.
    • There are notches securing the memory modules onto the motherboard.
    • Push down and outward on the both notches to release each memory module from the motherboard.
  3. Dell XPS 720 H2C Memory Modules Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove each memory module from its slot.
    • If you are reseating the memory modules, this is the time to clean them and make sure there isn't any dust build up on the surface.
Conclusie
Alexis Cervantes
279 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-16, Maness Spring 2013 Lid van Cal Poly, Team 4-16, Maness Spring 2013
CPSU-MANESS-S13S4G16
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 17
Altijd: 1,234
