Ga door naar hoofdinhoud
Dell XPS 720 H2C Hard Drive Replacement
G B
G B en 5 andere bijdragers
Voor het laatst geüpdatet op January 28, 2014
10 minuten
Gemiddeld
Actiemomenten
Heeft betere plaatjes nodig
A hard drive is a magnetized storage area. Your Operating System is stored on your hard drive, as well as all your software programs. This guide will instruct you on how to take the hard drive out of the computer so that you may replace or repair it.
Wat je nodig hebt
Gereedschap
  1. Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 1 van 2 Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 2 van 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 2 Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: stap 2, afbeelding 2 van 2
    • The hard drive is located the top-center area of the computer.
    • Carefully disconnect the data and power cables from the hard drive.
  3. Dell XPS 720 H2C Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Push the tabs on both sides of the hard drive bracket towards each other and slide the hard drive up and out of the hard drive bay.
  4. Dell XPS 720 H2C Hard Drive Replacement: stap 4, afbeelding 1 van 2 Dell XPS 720 H2C Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Unscrew the four 5mm screws on both sides of the hard drive using the Phillips #1 screwdriver and then remove the hard drive from the case.
Conclusie
G B
67 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 13
Altijd: 1,757
