Dell XPS 15 9530 Hard Drive Replacement
Inleiding
Ga naar stap 1How to replace the 2.5" hard drive of a Dell XPS 15 9530.
Wat je nodig hebt
Reparatiesets
Deze sets bevatten alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Remove the screws that secure the battery to the palm-rest assembly.
Disconnect the battery cable from the system board.
Lift the battery off the palm-rest assembly.
Remove the screws that secure the hard-drive assembly to the palm-rest assembly.
Using the pull tab, disconnect the hard-drive cable from the system board.
Lift the hard-drive assembly off the palm-rest assembly.
Disconnect the interposer from the hard-drive assembly.
Remove the screws that secure the hard-drive bracket to the hard drive.
Lift the hard drive off the hard-drive bracket.
To reassemble your device, follow these instructions in reverse order with the replacement hard drive.
