Ga door naar hoofdinhoud
Dell XPS 15 9510 Touchpad Replacement
Wat je nodig hebt
  1. Dell XPS 15 9510 Touchpad Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Touchpad Replacement: stap 2, afbeelding 1 van 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Lift the back panel of the laptop off and set it aside.
    Please do not miss this warning of it being sharp...
    After opening a few laptops for my office, I have generally been fine. But after opening my own XPS... I had sliced my finger badly.
    Alipoodle M - Antwoord
  4. Dell XPS 15 9510 Touchpad Replacement, Fan: stap 4, afbeelding 1 van 2 Dell XPS 15 9510 Touchpad Replacement, Fan: stap 4, afbeelding 2 van 2
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
    I had to remove three screws in total to remove the right fan. One that is circled in the image above, and two more which hold the small black bracket to the right of the right fan. This bracket, while seemingly there to protect/secure a ribbon cable, also secures the right fan. Perhaps the guide should be corrected to account for this? or maybe there are multiple variants.
    Cagdas Uzunahmet - Antwoord
  5. Dell XPS 15 9510 Touchpad Replacement: stap 5, afbeelding 1 van 2 Dell XPS 15 9510 Touchpad Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Touchpad Replacement: stap 7, afbeelding 1 van 2 Dell XPS 15 9510 Touchpad Replacement: stap 7, afbeelding 2 van 2
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Touchpad Replacement: stap 8, afbeelding 1 van 3 Dell XPS 15 9510 Touchpad Replacement: stap 8, afbeelding 2 van 3 Dell XPS 15 9510 Touchpad Replacement: stap 8, afbeelding 3 van 3
    • Repeat the previous step and remove the other fan.
  9. Dell XPS 15 9510 Touchpad Replacement, Battery: stap 9, afbeelding 1 van 2 Dell XPS 15 9510 Touchpad Replacement, Battery: stap 9, afbeelding 2 van 2
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  10. Dell XPS 15 9510 Touchpad Replacement: stap 10, afbeelding 1 van 1
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  11. Dell XPS 15 9510 Touchpad Replacement: stap 11, afbeelding 1 van 2 Dell XPS 15 9510 Touchpad Replacement: stap 11, afbeelding 2 van 2
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
  12. Dell XPS 15 9510 Touchpad Replacement, Heat Sink: stap 12, afbeelding 1 van 2 Dell XPS 15 9510 Touchpad Replacement, Heat Sink: stap 12, afbeelding 2 van 2
    • Remove the three 4.6 mm screws that secure the heat sink with a Phillips #00 screwdriver.
  13. Dell XPS 15 9510 Touchpad Replacement: stap 13, afbeelding 1 van 1
  14. Dell XPS 15 9510 Touchpad Replacement, Touchpad: stap 14, afbeelding 1 van 1
    • Remove the six 3 mm screws securing the touch pad with a Phillips #00 screw driver.
  15. Dell XPS 15 9510 Touchpad Replacement: stap 15, afbeelding 1 van 3 Dell XPS 15 9510 Touchpad Replacement: stap 15, afbeelding 2 van 3 Dell XPS 15 9510 Touchpad Replacement: stap 15, afbeelding 3 van 3
    • Flip up the black ZIF locking flap that secures the touchpad ribbon cable.
    • Disconnect the touch pad ribbon cable.
  16. Dell XPS 15 9510 Touchpad Replacement: stap 16, afbeelding 1 van 2 Dell XPS 15 9510 Touchpad Replacement: stap 16, afbeelding 2 van 2
    • Lift the touch pad up and out of the chassis.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Esmie
121 Reputatie
1 Handleiding geschreven
Één opmerking
This guide is incomplete. Step 13 shows removing the heatsink, then step 14 is removing the touchpad, but it's a missing a HUGE series of steps in between which is removing the motherboard to access the touchpad. As-is this guide is not usable.
Derek Selby - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 91
Altijd: 233
