Ga door naar hoofdinhoud
Dell XPS 13 9360 SSD Replacement
Wat je nodig hebt
  1. Dell XPS 13 9360 SSD Replacement, SSD (Solid State Drive): stap 1, afbeelding 1 van 1
    • Power off your laptop and unplug it from the charger.
  2. Dell XPS 13 9360 SSD Replacement: stap 2, afbeelding 1 van 2 Dell XPS 13 9360 SSD Replacement: stap 2, afbeelding 2 van 2
    • Close the laptop lid and place it so the bottom side faces up.
  3. Dell XPS 13 9360 SSD Replacement: stap 3, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 3, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 3, afbeelding 3 van 3
    • Use a Torx T5 screwdriver to remove eight 3 mm screws around the edge of the back cover.
  4. Dell XPS 13 9360 SSD Replacement: stap 4, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 4, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 4, afbeelding 3 van 3
    • Lift the small magnetic flap cover in the center of the back case.
    • Use a JIS J0 screwdriver to remove the 6 mm screw under the flap cover.
  5. Dell XPS 13 9360 SSD Replacement: stap 5, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 5, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 5, afbeelding 3 van 3
    • Wedge the guitar pick between the cover and the base of the laptop.
    • Start at the front edge of the base cover and continue around the perimeter of the laptop, carefully prying up the base cover.
    • Pull off the base cover.
    • As you use the guitar pick to work around the base cover, it will gradually loosen. You can then gently pull it off completely.
  6. Dell XPS 13 9360 SSD Replacement: stap 6, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 6, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery before removing the SSD.
    • Use the JIS J0 screwdriver to remove the single 2 mm screw securing the existing SSD.
    • The SSD will automatically "pop up".
    • Gently slide it out from the socket.
  7. Dell XPS 13 9360 SSD Replacement: stap 7, afbeelding 1 van 2 Dell XPS 13 9360 SSD Replacement: stap 7, afbeelding 2 van 2
    • Slide the new SSD into the slot at the same angle used when removing the old one.
    • Make sure to align the notches on the SSD correctly with the tab openings of the slot to avoid damaging the SSD and the PCIe slot.
    • Press down on the SSD gently to hold it down.
  8. Dell XPS 13 9360 SSD Replacement: stap 8, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 8, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 8, afbeelding 3 van 3
    • Follow the remaining instructions in reverse order to reassemble.
    • Make sure that when you replace the back cover you press down along the edges to ensure that it snaps back into place.
  9. Dell XPS 13 9360 SSD Replacement: stap 9, afbeelding 1 van 2 Dell XPS 13 9360 SSD Replacement: stap 9, afbeelding 2 van 2
    • Now you can power on the laptop again and use it!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Diana Ramirez-S.
293 Reputatie
1 Handleiding geschreven
Één opmerking
Simple instructions. Could have used a little more detail in step 6 on how to disconnect the battery cable.
Rich Stillman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 101
Altijd: 490
