Ga door naar hoofdinhoud
Dell XPS 13 9360 SSD Replacement
Diana Ramirez-S.
Diana Ramirez-S. en een andere bijdrager
Voor het laatst geüpdatet op June 11, 2024
20 - 35 minuten
Gemiddeld
If you need to replace or upgrade the SSD for your Dell XPS 13 9360 laptop, follow this guide.
Replacing the SSD on this model could help improve its storage space and performance. The model shown in this guide contains a 256 GB M.2 PCIe NVMe SSD, however, the model can upgrade to a 1 TB SSD.
Before you begin this repair, power off your computer and disconnect it from the charger. In addition, make sure to disconnect the battery before replacing the SSD. This will help prevent accidental damage to the computer or its electrical components.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Dell XPS 13 9360 SSD Replacement, SSD (Solid State Drive): stap 1, afbeelding 1 van 1
    • Power off your laptop and unplug it from the charger.
  2. Dell XPS 13 9360 SSD Replacement: stap 2, afbeelding 1 van 2 Dell XPS 13 9360 SSD Replacement: stap 2, afbeelding 2 van 2
    • Close the laptop lid and place it so the bottom side faces up.
  3. Dell XPS 13 9360 SSD Replacement: stap 3, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 3, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 3, afbeelding 3 van 3
    • Use a Torx T5 screwdriver to remove eight 3 mm screws around the edge of the back cover.
  4. Dell XPS 13 9360 SSD Replacement: stap 4, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 4, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 4, afbeelding 3 van 3
    • Lift the small magnetic flap cover in the center of the back case.
    • Use a JIS J0 screwdriver to remove the 6 mm screw under the flap cover.
  5. Dell XPS 13 9360 SSD Replacement: stap 5, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 5, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 5, afbeelding 3 van 3
    • Wedge the guitar pick between the cover and the base of the laptop.
    • Start at the front edge of the base cover and continue around the perimeter of the laptop, carefully prying up the base cover.
    • Pull off the base cover.
    • As you use the guitar pick to work around the base cover, it will gradually loosen. You can then gently pull it off completely.
  6. Dell XPS 13 9360 SSD Replacement: stap 6, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 6, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery before removing the SSD.
    • Use the JIS J0 screwdriver to remove the single 2 mm screw securing the existing SSD.
    • The SSD will automatically "pop up".
    • Gently slide it out from the socket.
  7. Dell XPS 13 9360 SSD Replacement: stap 7, afbeelding 1 van 2 Dell XPS 13 9360 SSD Replacement: stap 7, afbeelding 2 van 2
    • Slide the new SSD into the slot at the same angle used when removing the old one.
    • Make sure to align the notches on the SSD correctly with the tab openings of the slot to avoid damaging the SSD and the PCIe slot.
    • Press down on the SSD gently to hold it down.
  8. Dell XPS 13 9360 SSD Replacement: stap 8, afbeelding 1 van 3 Dell XPS 13 9360 SSD Replacement: stap 8, afbeelding 2 van 3 Dell XPS 13 9360 SSD Replacement: stap 8, afbeelding 3 van 3
    • Follow the remaining instructions in reverse order to reassemble.
    • Make sure that when you replace the back cover you press down along the edges to ensure that it snaps back into place.
  9. Dell XPS 13 9360 SSD Replacement: stap 9, afbeelding 1 van 2 Dell XPS 13 9360 SSD Replacement: stap 9, afbeelding 2 van 2
    • Now you can power on the laptop again and use it!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Diana Ramirez-S.
293 Reputatie
1 Handleiding geschreven
Één opmerking
Simple instructions. Could have used a little more detail in step 6 on how to disconnect the battery cable.
Rich Stillman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 99
Altijd: 494
