Dell Vostro 3550 RAM Replacement
Inleiding
Ga naar stap 1This guide will walk through all the necessary steps in order to replace the RAM for the Dell Vostro 3550. RAM is one of the most common components that users upgrade in their devices. The primary reason why users decide to upgrade their RAM is to be able to run more applications at the same time on their computer.
Wat je nodig hebt
Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
Lift the access panel up at an angle and remove it from the computer.
Push outward on the two release tabs securing either side of the top RAM module.
Één andere persoon heeft deze handleiding voltooid.
