Ga door naar hoofdinhoud
Dell Precision M6400 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond en 2 andere bijdragers
Voor het laatst geüpdatet op November 15, 2022
15 - 30 minuten
Eenvoudig
Door de gemeenschap gemaakte handleiding
Wat je nodig hebt
Reparatiesets
Deze sets bevatten alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
  1. Dell Precision M6400 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Hard Drive Replacement, Base Cover: stap 2, afbeelding 1 van 1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Loosen the two captive screws on the HDD1 carrier, and remove the carrier.
    • Push in, then pull up on the safety loop to remove the cover.
    • Use the pull tab to disconnect the HDD1 from the connector on the system board, and remove the HDD1 from the computer.
  4. Dell Precision M6400 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the two M3 x 3-mm screws that secure the pull tab to the HDD1.
    • Set the pull tab aside to use with the replacement HDD1.
  5. Dell Precision M6400 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the two M3 x 3-mm screws that secure the carrier to the computer.
    • Pull up on the pull tab to remove the carrier.
  6. Dell Precision M6400 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove the two M3 x 3-mm screws that secure the carrier to the HDD2.
    • Remove the carrier from the HDD2. If your computer does not have an HDD2, remove the hard drive place-holder from the carrier.
    • Remove the interposer from the HDD2 or the place-holder, and set the interposer aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnathan Hammond
45.210 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 31
Altijd: 4,375
