Ga door naar hoofdinhoud
Dell Precision M3800 Touch Pad Replacement
Brianna Hitchcock
Brianna Hitchcock en 3 andere bijdragers
Voor het laatst geüpdatet op December 6, 2019
15 - 20 minuten
Gemiddeld
Door de gemeenschap gemaakte handleiding
If the Dell Precision M3800 touchpad is unresponsive or not working, use this guide to replace the touchpad.
The touchpad works as the “mouse” for the laptop, and an unresponsive touchpad would stop the user from using the laptop, unless the user uses an external mouse.
Before beginning, be sure to power down the laptop, and unplug from the external power source(s).
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Dell Precision M3800 Touch Pad Replacement, Back Cover: stap 1, afbeelding 1 van 2 Dell Precision M3800 Touch Pad Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Touch Pad Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Touch Pad Replacement, Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Touch Pad Replacement, Touch Pad: stap 4, afbeelding 1 van 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: stap 4, afbeelding 2 van 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: stap 4, afbeelding 3 van 3
    • Remove the wire that connects the touch pad with the motherboard with a hooked pry tool (Spudger 3) and by pulling the pull tab to safely remove the wire.
  5. Dell Precision M3800 Touch Pad Replacement: stap 5, afbeelding 1 van 2 Dell Precision M3800 Touch Pad Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two 2mm silver screws.
  6. Dell Precision M3800 Touch Pad Replacement: stap 6, afbeelding 1 van 1
    • Remove the touch pad from the laptop. If needed, use a prying tool to remove the touch pad.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 23
Altijd: 1,104
