Dell Latitude E4310 Display Replacement
Inleiding
Ga naar stap 1This guide walks through how to remove and replace a display on the Dell Latitude E4310 laptop in the event of a broken or bad display.
Wat je nodig hebt
Open up the laptop and flatten it down on a workable surface.
Turn it around so that the screen is closest to you.
Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
Remove the bezel.
6 andere personen hebben deze handleiding voltooid.
