Ga door naar hoofdinhoud
Dell Inspiron E1505 RAM Replacement
Anthony Toscano
Anthony Toscano en 2 andere bijdragers
Voor het laatst geüpdatet op December 19, 2016
25 minuten
Moeilijk
Actiemomenten
Betere introductie
Wat je nodig hebt
Gereedschap
  1. Dell Inspiron E1505 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 RAM Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 RAM Replacement: stap 3, afbeelding 1 van 1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 RAM Replacement: stap 4, afbeelding 1 van 1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
  5. Dell Inspiron E1505 RAM Replacement, RAM: stap 5, afbeelding 1 van 1
    • On the back of the laptop there is a compartment for the RAM for easy access.
    • It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
    • Unscrew the two screws with a screwdriver and lift the backplate up to unveil the RAM.
  6. Dell Inspiron E1505 RAM Replacement: stap 6, afbeelding 1 van 1
    • There are two metal tabs on each of the sticks of RAM.
    • Press each of the tabs outward and the RAM stick should slide up.
    • Gently pull the stick of RAM out and get the product number to get replacement RAM.
    • Do this for both of the sticks of RAM.
  7. Dell Inspiron E1505 RAM Replacement: stap 7, afbeelding 1 van 1
    • Inserting new RAM: Line up the RAM by making sure the slot on the RAM stick lines up with the slot on the laptop.
    • Insert it at slight angle while it lined up.
    • Gently press the stick of RAM down until the two metal tabs snap it back in. Repeat this as necessary.
Conclusie
Anthony Toscano
323 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-7, Martin Fall 2016 Lid van UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 444
