Ga door naar hoofdinhoud
Dell Inspiron 530 DCMF Graphics Card Replacement
Drew Cunningham
Drew Cunningham en 6 andere bijdragers
Voor het laatst geüpdatet op June 11, 2024
10 - 15 minuten
Gemiddeld
Actiemomenten
Stappen inkorten
This guide will walk you through how to replace the graphics card in your Dell Inspiron 530 DCMF.
The graphics card is responsible for rendering images, videos, and any animations on your computer. The higher quality of graphics card, the higher the resolution images and videos will appear.
Be sure to power off the desktop and remove all sources of power before replacing your graphics card.
Wat je nodig hebt
Gereedschap
  1. Dell Inspiron 530 DCMF Graphics Card Replacement, Graphics Card: stap 1, afbeelding 1 van 2 Dell Inspiron 530 DCMF Graphics Card Replacement, Graphics Card: stap 1, afbeelding 2 van 2
    • Remove the two screws.
    • Slide out the panel back.
  2. Dell Inspiron 530 DCMF Graphics Card Replacement: stap 2, afbeelding 1 van 1
    • Locate the graphics card. It can be identified by its position on the motherboard and built-in fan.
  3. Dell Inspiron 530 DCMF Graphics Card Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 530 DCMF Graphics Card Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the screw.
    • Remove the metal piece that holds the graphics card in place.
  4. Dell Inspiron 530 DCMF Graphics Card Replacement: stap 4, afbeelding 1 van 1
    • The graphics card can now be taken out by sliding it upwards.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Drew Cunningham
656 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-1, Kish Spring 2015 Lid van UMass Dartmouth, Team 5-1, Kish Spring 2015
UMASSD-KISH-S15S5G1
5 Leden
11 handleidingen geschreven
Één opmerking
The one I am working on has on board video.... help? (DCMF)
akawarren - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 3,015
