Dell Inspiron 1545 Power Button Board Replacement
Inleiding
Ga naar stap 1The power button board is responsible for the communication between the power button and the motherboard. If your power button is either malfunctioning, not working at all, or causing the laptop to randomly shut off, you can use this guide to repair or replace the units power button board.
Wat je nodig hebt
Turn the laptop off and disconnect it from all power sources.
Turn the laptop over so that the bottom is facing upwards.
