Ga door naar hoofdinhoud
Dell Inspiron 15-7547 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Dell Inspiron 15-7547 Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-7547 Battery Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 15-7547 Battery Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 15-7547 Battery Replacement: stap 5, afbeelding 3 van 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Één andere persoon heeft deze handleiding voltooid.
Claro
591 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 2,090
