Ga door naar hoofdinhoud
Dell Inspiron 15-3531 Keyboard Replacement
Kody Dahlke
Kody Dahlke en 6 andere bijdragers
Voor het laatst geüpdatet op June 19, 2024
5 - 10 minuten
Eenvoudig
As laptop keyboards age, they may lose keys or stop responding to any interaction and may need to be replaced. Make sure the keyboard is not near any hazardous materials that could destroy the keyboard during the removal process.
Wat je nodig hebt
Gereedschap
  1. Dell Inspiron 15-3531 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 15-3531 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 15-3531 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 3 Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: stap 2, afbeelding 2 van 3 Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: stap 2, afbeelding 3 van 3
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard with a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting it out because there is a cable connecting the keyboard to the laptop.
  3. Dell Inspiron 15-3531 Keyboard Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 15-3531 Keyboard Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 15-3531 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
Conclusie
Kody Dahlke
742 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G5, Leahy Spring 2018 Lid van USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 22
Altijd: 628
