Dell Inspiron 15-3531 Fan Replacement
Inleiding
Ga naar stap 1As laptop fans age, they have a chance to break and may need to be replaced. Make sure the motherboard ventilation fan is at room temperature and not near any hazardous materials that could destroy it during the removal process.
Wat je nodig hebt
Gereedschap
Toon meer…
Flip the laptop over.
Slide the latches toward the edges to unlock the battery.
Lift the battery out of the laptop.
Loosen the two screws on the access panel using the PH1 head screwdriver.
Pry the access panel open with the spudger.
Turn over the motherboard.
Disconnect the fan power cable.
Remove the 8.65 mm screw holding the fan casing to the laptop frame using a PH0 head screwdriver.
Één andere persoon heeft deze handleiding voltooid.
