Dell Inspiron 14R SE 7420 Hard Drive Replacement
Inleiding
Ga naar stap 1In this guide, we will be showing you how to remove and replace the Hard Drive.
Wat je nodig hebt
Gereedschap
Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
Remove the screws that secure the hard-drive assembly to the computer base.
Make a note of the hard-drive cable routing and remove the cable from the routing guides.
Lift the hard-drive assembly along with its cable away from the computer base.
Pull the interposer to disconnect the hard-drive cable from the hard-drive.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Connect the hard-drive cable interposer to the hard drive.
Place the hard-drive assembly in the hard-drive bay on the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
Route the hard-drive cable through the routing guides on the computer base.
Connect the hard-drive cable to the system-board connector.
