Ga door naar hoofdinhoud
Dell Inspiron 13-5368 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 13-5368 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 13-5368 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 13-5368 Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 andere personen hebben deze handleiding voltooid.
Matt Sugrim
1.042 Reputatie
6 handleidingen geschreven
USF Tampa, Team S14-G6, Boczar Fall 2017 Lid van USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Leden
13 handleidingen geschreven
3 opmerkingen
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - Antwoord
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - Antwoord
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 152
Altijd: 24,895
