Dell Inspiron 1122 M102z Hard Drive Replacement
Inleiding
Ga naar stap 1In this guide, we will show you how to remove and replace the Hard Drive.
Wat je nodig hebt
Remove the two screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Replace the four screws that secure the hard-drive bracket to the hard drive.
Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
Replace the two screws that secure the hard-drive assembly to the computer base.
