Ga door naar hoofdinhoud
Dell Inspiron 11-3168 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3168 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3168 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Battery Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 11-3168 Battery Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 11-3168 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Battery Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 11-3168 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Battery Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 11-3168 Battery Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Battery Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 11-3168 Battery Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 11-3168 Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the battery.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Phillip Dennis - Antwoord
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
Matthew Roomsburg - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 936
