Ga door naar hoofdinhoud
Casablanca Intelli-Touch W-11 control testing
Wayne Seltzer
Wayne Seltzer en een andere bijdrager
Voor het laatst geüpdatet op June 26, 2024
10 minuten
Gemiddeld
Door de gemeenschap gemaakte handleiding
Here's how to tell if your Casablanca Intelli Touch W-11 wall switch is working.
  1. Casablanca Intelli-Touch W-11 control testing, Test wiring: stap 1, afbeelding 1 van 1
    • Connect the hot side of an AC power cord to the Line In to the W-11
    • Connect the neutral side to a light bulb, lamp, etc.
    • Connect the Line Out of the WC-11 to the other side of the light bulb. Use a jumper wire.
    • Connect the oscilloscope leads to the hot and neutral sides of the light bulb.
    • Be sure that all the wiring is secure so that nothing shorts out during the testing.
    • Plug in the AC plug to a 110 volt outlet
  2. Casablanca Intelli-Touch W-11 control testing, Power test: stap 2, afbeelding 1 van 1
    • Turn on the W-11 power switch.
    • Does the light turn on? If not, check your wiring.
    • Turn off the power, take apart the W-11 and test the power switch with a continuity tester/multimeter.
    • Set up the oscilloscope to observe the AC sine wave.
  3. Casablanca Intelli-Touch W-11 control testing, Test the light button: stap 3, afbeelding 1 van 1
    • Press the Light button
    • Check the ossilloscope.
    • Do you see the small signal that appears on the rising side of the AC sine wave?
  4. Casablanca Intelli-Touch W-11 control testing, Test the fan button: stap 4, afbeelding 1 van 1
    • Press the fan button
    • Do you see the signal on the falling side of the AC sine wave?
  5. Casablanca Intelli-Touch W-11 control testing, Test both switches: stap 5, afbeelding 1 van 1
    • Press the fan and light switches simultaneously.
    • Do you see the signals on both the rising and falling sides of the AC sine wave?
Eindstreep
Wayne Seltzer
1.732 Reputatie
10 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
45 Leden
702 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 701
