Ga door naar hoofdinhoud
Canon Powershot Pro1 Battery Replacement
Seana Meegan
Seana Meegan en 3 andere bijdragers
Voor het laatst geüpdatet op June 9, 2022
3 minuten
Zeer eenvoudig
Use this guide to replace a dead or faulty battery. No difficult steps or tools are required for this process. The PowerShot Pro1 requires a lithium ion battery pack. It can use four kinds of lithium ion batteries: BP-511A, BP-511, BP-512, or BP-514.
  1. Canon Powershot Pro1 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Battery Replacement: stap 2, afbeelding 1 van 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Battery Replacement: stap 3, afbeelding 1 van 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Battery Replacement: stap 4, afbeelding 1 van 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
Conclusie
Seana Meegan
677 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,149
