Ga door naar hoofdinhoud
Canon PowerShot S400 LCD Screen Replacement
Ross Bryan
Ross Bryan en 12 andere bijdragers
Voor het laatst geüpdatet op February 20, 2025
30 - 45 minuten
Gemiddeld
Betere introductie
Student in uitvoering
This guide illustrates how to replace the LCD screen on the Canon PowerShot S400.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Canon PowerShot S400 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 2 Canon PowerShot S400 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 2
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
  2. Canon PowerShot S400 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
  3. Canon PowerShot S400 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot S400 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot S400 LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws hold in place.
  4. Canon PowerShot S400 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot S400 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
  5. Canon PowerShot S400 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
  6. Canon PowerShot S400 LCD Screen Replacement: stap 6, afbeelding 1 van 3 Canon PowerShot S400 LCD Screen Replacement: stap 6, afbeelding 2 van 3 Canon PowerShot S400 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
  7. Canon PowerShot S400 LCD Screen Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot S400 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
  8. Canon PowerShot S400 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
  9. Canon PowerShot S400 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot S400 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the LCD screen and set it aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ross Bryan
374 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-19, Amido Winter 2011 Lid van Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 31
Altijd: 3,234
