Ga door naar hoofdinhoud
Canon PowerShot A4000 IS Flash Replacement
Ansley Gardner
Ansley Gardner en 3 andere bijdragers
Voor het laatst geüpdatet op March 10, 2020
Geen schatting
Gemiddeld
Betere introductie
Wat je nodig hebt
Gereedschap
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: stap 1, afbeelding 1 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: stap 1, afbeelding 2 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: stap 1, afbeelding 3 van 3
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot A4000 IS Flash Replacement: stap 2, afbeelding 2 van 2
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: stap 3, afbeelding 1 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: stap 3, afbeelding 2 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: stap 3, afbeelding 3 van 3
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Conclusie
Ansley Gardner
761 Reputatie
7 handleidingen geschreven
Clemson, Team 1-3, Benson Fall 2014 Lid van Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Leden
17 handleidingen geschreven
Één opmerking
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 1,816
