Ga door naar hoofdinhoud
Canon EOS Rebel G Back Panel Latch Replacement
Wat je nodig hebt
  1. Canon EOS Rebel G Back Panel Latch Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Back Panel Latch Replacement: stap 2, afbeelding 1 van 2 Canon EOS Rebel G Back Panel Latch Replacement: stap 2, afbeelding 2 van 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Back Panel Latch Replacement: stap 3, afbeelding 1 van 3 Canon EOS Rebel G Back Panel Latch Replacement: stap 3, afbeelding 2 van 3 Canon EOS Rebel G Back Panel Latch Replacement: stap 3, afbeelding 3 van 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Back Panel Latch Replacement, Back Panel Latch: stap 4, afbeelding 1 van 1
    • Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
    • Two 4.3 mm Phillips screws
  5. Canon EOS Rebel G Back Panel Latch Replacement: stap 5, afbeelding 1 van 1
    • Open the back panel by pushing the locking latch up.
    • Lift the latch cover off of the camera body.
  6. Canon EOS Rebel G Back Panel Latch Replacement: stap 6, afbeelding 1 van 1
    • Slide the side latch (for the back door) up and then lift straight away from the camera body.
    • Sometimes the latch will detach while pushing it up.
Conclusie
Zach
46 Reputatie
8 handleidingen geschreven
Cal Poly, Team 14-9, Forte Spring 2012 Lid van Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Leden
36 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 3,102
