Ga door naar hoofdinhoud
Button Controller Board Replacement
Wat je nodig hebt
    1. Button Controller Board Replacement, Exterior Housing: stap 1, afbeelding 1 van 3 Button Controller Board Replacement, Exterior Housing: stap 1, afbeelding 2 van 3 Button Controller Board Replacement, Exterior Housing: stap 1, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      iOpener
      $24.95
      • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
      • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
      • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
      Vraag FixBot
      Voeg opmerking toe
    1. Button Controller Board Replacement, Lower Half Casing: stap 2, afbeelding 1 van 3 Button Controller Board Replacement, Lower Half Casing: stap 2, afbeelding 2 van 3 Button Controller Board Replacement, Lower Half Casing: stap 2, afbeelding 3 van 3
      • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
      • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
      • Lift and remove the counterweight.
      Vraag FixBot
      Voeg opmerking toe
    2. Button Controller Board Replacement: stap 3, afbeelding 1 van 3 Button Controller Board Replacement: stap 3, afbeelding 2 van 3 Button Controller Board Replacement: stap 3, afbeelding 3 van 3
      • Lift and remove the plastic casing.
      • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
      • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
      Vraag FixBot
      Voeg opmerking toe
    1. Button Controller Board Replacement, Preliminary Main Board: stap 4, afbeelding 1 van 2 Button Controller Board Replacement, Preliminary Main Board: stap 4, afbeelding 2 van 2
      • Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
      Vraag FixBot
      Voeg opmerking toe
    2. Button Controller Board Replacement: stap 5, afbeelding 1 van 1
      • Peel away the black tape covering the red wires that connect to the PCB.
      Vraag FixBot
      Voeg opmerking toe
    3. Button Controller Board Replacement: stap 6, afbeelding 1 van 1
      • There is ribbon wiring under this PCB. Be careful not to damage it while removing the PCB.
      • Slowly lift the PCB away from the rest of the device
      • Remove the ribbon by first removing the brown insert piece from the connector on the button board
      • Pull the ribbon out of the connector on the button board by the blue tab.
      Vraag FixBot
      Voeg opmerking toe
    4. Button Controller Board Replacement: stap 7, afbeelding 1 van 1
      • Carefully disconnect the white 11-pin connector from the main board.
      • Pull firmly on the connector and use a screwdriver to pry it slightly if necessary.
      Vraag FixBot
      Voeg opmerking toe
    1. Button Controller Board Replacement, Button Controller Board: stap 8, afbeelding 1 van 2 Button Controller Board Replacement, Button Controller Board: stap 8, afbeelding 2 van 2
      • Remove the four 6 mm screws that secure the button controller PCB to the rest of the device; you will need a Phillips #2 driver for this task.
      • Note: Since the main board is on top of this PCB, you may need to move the main board out of the way to access the screws.
      • Lift the PCB away from the rest of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Button Controller Board Replacement: stap 9, afbeelding 1 van 1
      • Peel away the glue connecting the red and black wire with the PCB board.
      Vraag FixBot
      Voeg opmerking toe
    3. Button Controller Board Replacement: stap 10, afbeelding 1 van 1
      • Using a soldering wick and a soldering iron, remove the solder from the red and black wire ends on the other side of the board.
      • For more information on soldering, refer to iFixit's soldering guide.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jerrell
730 Reputatie
7 handleidingen geschreven
Cal Poly, Team 11-50, Amido Spring 2014 Lid van Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Leden
34 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 1,565
