Inleiding
Use this guide to replace a damaged or malfunctioning control panel on your Brother IntelliFax-2840. The entire panel is replaced as a unit, including the buttons and display.
Wat je nodig hebt
Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
Één andere persoon heeft deze handleiding voltooid.
